Snapfōn ezONE LCD Screen Replacement
  1. Snapfōn ezONE LCD Screen Replacement, Remove the battery cover: step 1, image 1 of 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
    Ask FixBot
  2. Snapfōn ezONE LCD Screen Replacement, Remove the battery: step 2, image 1 of 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
    Ask FixBot
  3. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: step 3, image 1 of 2 Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
    Ask FixBot
  4. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: step 4, image 1 of 3 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: step 4, image 2 of 3 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: step 4, image 3 of 3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
    Ask FixBot
  5. Snapfōn ezONE LCD Screen Replacement, Separate the case: step 5, image 1 of 3 Snapfōn ezONE LCD Screen Replacement, Separate the case: step 5, image 2 of 3 Snapfōn ezONE LCD Screen Replacement, Separate the case: step 5, image 3 of 3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
    Ask FixBot
  6. Snapfōn ezONE LCD Screen Replacement, Remove the volume slider: step 6, image 1 of 1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
    Ask FixBot
  7. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: step 7, image 1 of 3 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: step 7, image 2 of 3 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: step 7, image 3 of 3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
    Ask FixBot
  8. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: step 8, image 1 of 3 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: step 8, image 2 of 3 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: step 8, image 3 of 3
    • Pry the LCD screen off of the circuit board using the opening tool. The screen is connected to the motherboard with light adhesive, which is easy to remove.
    • The LCD screen will still be connected to the circuit board by a ribbon cable.
    Ask FixBot
  9. Snapfōn ezONE LCD Screen Replacement, Disconnect the display: step 9, image 1 of 1
    • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
    • Be careful! High temperatures from the soldering iron may result in injury.
    • Only make contact with the solder connection so that none of the phone’s components are damaged by the heat.
    Ask FixBot
  10. Snapfōn ezONE LCD Screen Replacement, Remove the display: step 10, image 1 of 2 Snapfōn ezONE LCD Screen Replacement, Remove the display: step 10, image 2 of 2
    • Once you heat the solder connection, lightly tug the ribbon cable free. The LCD screen will be completely removed from the device.
    Ask FixBot
To reassemble your device with a new LCD screen, follow these instructions in reverse order.
Note: you will need to use the soldering iron again to attach the new LCD screen ribbon to the circuit board.
John Bender
818 Reputation
8 Guides authored
Clemson, Team 6-5, Benson Spring 2014 Member of Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 36
All Time: 736
