Up to 20% off select tools
Smoke Detector Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
21
Past 7 Days:
112
Past 30 Days:
490
All Time:
17,861
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Parts
Introduction
Go to step 1 ↓
Smoke detectors are used to keep homes safe from fire. A beeping smoke detector means that it is time for a new battery. This guide will walk users through the steps of replacing a battery in a home smoke detector.
    1. Smoke Detector Battery Replacement, Battery Replacement: step 1, image 1 of 1
      • Remove the smoke detector from the ceiling by twisting the smoke detector counter-clockwise.
      Ask FixBot
    2. Smoke Detector Battery Replacement: step 2, image 1 of 1
      • Open the battery compartment in the back of the smoke detector.
      Ask FixBot
    3. Smoke Detector Battery Replacement: step 3, image 1 of 1
      • Lift the battery out of the battery compartment.
      • Dispose of the battery properly.
      Ask FixBot
    4. Smoke Detector Battery Replacement: step 4, image 1 of 1
      • Push the red switch down with your finger.
      Ask FixBot
    5. Smoke Detector Battery Replacement: step 5, image 1 of 3 Smoke Detector Battery Replacement: step 5, image 2 of 3 Smoke Detector Battery Replacement: step 5, image 3 of 3
      • Place the new battery on top of the red switch.
      • Push the new battery into the battery compartment.
      • Make sure the red switch remains down while the battery is in the battery compartment.
      Ask FixBot
3 other people completed this guide.
Author
with
Lila Lowe
195 Reputation
1 Guide authored
Texas Tech, Team 3-3, Rauch SU 2015 Member of Texas Tech, Team 3-3, Rauch SU 2015
TTU-RAUCH-SU15S3G3
3 Members
12 Guides authored
1 Guide Comment
Don't want to replce smoke detector battery frequently, you can try Ultrable 10-year long life 1200mAh 9V lithium battery at http://www.ultrablecell.com/en/Products/....
loganq - Reply Share
Past 24 Hours: 21
Past 7 Days: 112
Past 30 Days: 490
All Time: 17,861
