Smartab STJR700 Speakers Replacement
    1. Smartab STJR700 Speakers Replacement, Speakers: step 1, image 1 of 3 Smartab STJR700 Speakers Replacement, Speakers: step 1, image 2 of 3 Smartab STJR700 Speakers Replacement, Speakers: step 1, image 3 of 3
      • Power off device. Place it face down.
      • Unscrew the 4 perimeter screws, using a PH000 screwdriver from iFixit kit.
      Ask FixBot
    2. Smartab STJR700 Speakers Replacement: step 2, image 1 of 1
      • Using a plastic opening tool or metal spudger, begin to gently pry the rear case down and away from the display.Slowly wiggle the tool up and down to pry open the tablet. Once the rear case is fully removed place it to the side.
      Ask FixBot
    3. Smartab STJR700 Speakers Replacement: step 3, image 1 of 3 Smartab STJR700 Speakers Replacement: step 3, image 2 of 3 Smartab STJR700 Speakers Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers carefully remove tape that is holding the black and red intertwined cables to the motherboard. Place tape to the side as is will be needed for reassembly.
      Ask FixBot
    4. Smartab STJR700 Speakers Replacement: step 4, image 1 of 1
      • Remove the 2 screws holding the speaker to the front panel. Use a PH000 screwdriver from iFixit kit. Place the screws to the side as they will be needed for reassembly.
      Ask FixBot
    5. Smartab STJR700 Speakers Replacement: step 5, image 1 of 1
      • Use the metal spudger to remove the speaker from the front panel of the tablet.
      Ask FixBot
    6. Smartab STJR700 Speakers Replacement: step 6, image 1 of 1
      • Disconnect black and red intertwined wire from the motherboard.
      Ask FixBot
Moriah Wiggins
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 454
