Up to 20% off select tools
Smartab STJR700 Screen/Digitizer Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
80
All Time:
1,803
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: step 1, image 1 of 2 Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: step 1, image 2 of 2
      • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
      Ask FixBot
    2. Smartab STJR700 Screen/Digitizer Replacement: step 2, image 1 of 1
      • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
      • the front panel should now be exposing the digitizer along with the other electronic components of the device.
      Ask FixBot
    3. Smartab STJR700 Screen/Digitizer Replacement: step 3, image 1 of 2 Smartab STJR700 Screen/Digitizer Replacement: step 3, image 2 of 2
      • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
      • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
      • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
      Ask FixBot
Author
with
Tianna Edwards
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 80
All Time: 1,803
