Smartab STJR700 Charging Port Replacement
    1. Smartab STJR700 Charging Port Replacement, Charging Port: step 1, image 1 of 1
      • Power off the device by holding down the lock button. Remove the case from the tablet and place it face down.
      Ask FixBot
    2. Smartab STJR700 Charging Port Replacement: step 2, image 1 of 1
      • Unscrew all four corner screws using the PH000 screwdriver head found in the iFixit kit.
      Ask FixBot
    3. Smartab STJR700 Charging Port Replacement: step 3, image 1 of 1
      • CAUTION: Avoid touching the display.
      • Pry open the tablet using a metal spudger. Set aside the back panel.
      Ask FixBot
    4. Smartab STJR700 Charging Port Replacement: step 4, image 1 of 1
      • Locate the charging port.
      Ask FixBot
    5. Smartab STJR700 Charging Port Replacement: step 5, image 1 of 2 Smartab STJR700 Charging Port Replacement: step 5, image 2 of 2
      • Unscrew all the labeled screws using the PH000 screwdriver head.
      Ask FixBot
    6. Smartab STJR700 Charging Port Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove all pieces of tape using the tweezers provided in the iFixit kit.
      • Remove the two ribbon cables affixed to the camera.
      Ask FixBot
    7. Smartab STJR700 Charging Port Replacement: step 7, image 1 of 1
      • Remove the motherboard component from the screen and display.
      • Because the charging port is soldered onto the motherboard, the motherboard must be replaced by one specifically made for the Smartab STJR700.
      Ask FixBot
Thi Le
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,225
