Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓If the main camera glass of your Smartab STJR700 camera is broken, you can either remove and replace the glass on the lens, or replace the whole camera lens.
Removing the glass on the lens while the Smartab STJR700 is still assembled may cause small pieces of glass to fall into the camera, but it is a faster method that requires less disassembly of the device.
Replacing the whole camera lens is a longer process, and requires removing the back panel, but it is less likely to damage the camera itself. This procedure includes replacing the glass lens and the camera bezel, and will require replacement rear glass adhesive.
FUse a screwdriver to remove the screws on the back cover of the Smartab.
Remove the cover to reveal the inside of the tablet.
To replace the camera lens, start by removing the broken glass by using tweezers.
If the new lens has adhesive, make sure that all the old adhesive is removed from the frame so that the lens does not stick out, and so a tighter seal is formed.
Once the glass is removed, place the new camera lense by peeling off the upper film and align the glass with the ring.
