Introduction
Go to step 1 ↓Follow this guide to replace the grip on your FixHub Smart Soldering Iron.
Blue LED: The iron has cooled below 40 °C (100 °F), and the tip is safe to touch.
Purple LED: When pulsing, the iron is actively heating up or cooling down. When static, the iron is in Idle Mode. The iron tip is not safe to touch.
Orange LED: The iron has reached the set temperature and is ready to solder. The iron tip is not safe to touch.
Orange: ON
Blue: OFF
Slide the power switch to the blue OFF position.
Leave the soldering iron connected until the indicator ring turns blue, indicating it's now safe to touch the soldering iron tip.
Twist the blue cable collar counter-clockwise and pull up to release it from the iron.
Disconnect the USB-C cable from the Smart Soldering Iron.
Firmly grasp the base of the tip and pull it away from the front of the iron handle to remove it.
Use a Phillips screwdriver to remove the three blue 3.4 mm‑long screws securing the blue end cap.
Use a Phillips screwdriver to remove the one black 3.4 mm‑long screw at the base of the enclosure.
Pull to remove the blue end cap from the rest of the iron handle.
Grasp the end of the main board that sticks out from inside of the soldering iron handle.
Pull to slide the main board out of the handle.
Twist the iron enclosure below the grip and pull to separate the grip from the enclosure. Just the grip remains.
To reassemble your Smart Soldering Iron, follow these instructions in reverse order.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
