Up to 20% off select tools
SleepTracker Elite Battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
95
All Time:
1,809
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. SleepTracker Elite Battery Replacement, Battery: step 1, image 1 of 3 SleepTracker Elite Battery Replacement, Battery: step 1, image 2 of 3 SleepTracker Elite Battery Replacement, Battery: step 1, image 3 of 3
      • You will need:
      • CR 2032 Battery
      • Philips #0 screwdriver
      • Something to pop the battery out, like a thin spudger, or a #2 slot screwdriver.
      Ask FixBot
    2. SleepTracker Elite Battery Replacement: step 2, image 1 of 2 SleepTracker Elite Battery Replacement: step 2, image 2 of 2
      • Remove these four screws. They're all the same size.
      Ask FixBot
    3. SleepTracker Elite Battery Replacement: step 3, image 1 of 2 SleepTracker Elite Battery Replacement: step 3, image 2 of 2
      • Lift off the case back.
      • Underneath, you'll see a sheet of plastic film. It should be possible to remove the battery without removing the film, if you're careful, but I didn't want to risk bending or tearing the plastic.
      • If you do take the plastic off, beware of maneuvering it over the three springs in the upper left, and the small prong that sticks out over the battery. You'll need to be sure to arrange the plastic carefully over these obstructions when re-assembling.
      Ask FixBot
    4. SleepTracker Elite Battery Replacement: step 4, image 1 of 1
      • Insert spudger or flat screwdriver in the notch indicated by the arrow, and lever out the battery.
      • The new battery should insert the same way the old one came out, and snap into place.
      Ask FixBot
Mark Boszko
131 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 95
All Time: 1,809
