Skullcandy UPROCK Earpiece Wiring Replacement
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: step 1, image 1 of 1
    • Remove the cushion from the ear piece.
    Ask FixBot
  2. Skullcandy UPROCK Earpiece Wiring Replacement: step 2, image 1 of 2 Skullcandy UPROCK Earpiece Wiring Replacement: step 2, image 2 of 2
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
    Ask FixBot
  3. Skullcandy UPROCK Earpiece Wiring Replacement: step 3, image 1 of 2 Skullcandy UPROCK Earpiece Wiring Replacement: step 3, image 2 of 2
    • Find the wires connected to the speaker and check if they are intact.
    Ask FixBot
  4. Skullcandy UPROCK Earpiece Wiring Replacement: step 4, image 1 of 1
    • If a wire is broken, use a soldering iron to reattach it to the speaker.
    • To learn how to solder, read the How To Solder and Desolder Connections Guide.
    • After soldering is complete, the wires should look like this.
    Ask FixBot
Finish Line
2 other people completed this guide.
1 Guide Comment
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 45
All Time: 6,717
