Skullcandy Mix Master DJ Mylar Driver Replacement
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: step 1, image 1 of 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: step 1, image 2 of 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: step 1, image 3 of 3
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
    Ask FixBot
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: step 2, image 1 of 1
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
    Ask FixBot
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: step 3, image 1 of 2 Skullcandy Mix Master DJ Mylar Driver Replacement: step 3, image 2 of 2
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
    Ask FixBot
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: step 4, image 1 of 2 Skullcandy Mix Master DJ Mylar Driver Replacement: step 4, image 2 of 2
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
    Ask FixBot
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: step 5, image 1 of 2 Skullcandy Mix Master DJ Mylar Driver Replacement: step 5, image 2 of 2
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
    Ask FixBot
Sean Herlihy
117 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 1,903
