Skullcandy Crusher Wireless Folding Hinge Replacement
  1. Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: step 1, image 1 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: step 1, image 2 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: step 1, image 3 of 3
    • Extend and fold the hinge of the headphones you are trying to replace.
    Ask FixBot
  2. Skullcandy Crusher Wireless Folding Hinge Replacement: step 2, image 1 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement: step 2, image 2 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement: step 2, image 3 of 3
    • Remove two 14 mm Torx T6 screws on the underside of the headband.
    Ask FixBot
  3. Skullcandy Crusher Wireless Folding Hinge Replacement: step 3, image 1 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement: step 3, image 2 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement: step 3, image 3 of 3
    • Pry the speaker away from the headband with a slight force.
    Ask FixBot
  4. Skullcandy Crusher Wireless Folding Hinge Replacement: step 4, image 1 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement: step 4, image 2 of 3 Skullcandy Crusher Wireless Folding Hinge Replacement: step 4, image 3 of 3
    • Remove two 5 mm Phillips #1 screws on the underside of the headband.
    Ask FixBot
  5. Skullcandy Crusher Wireless Folding Hinge Replacement: step 5, image 1 of 2 Skullcandy Crusher Wireless Folding Hinge Replacement: step 5, image 2 of 2
    • Remove the top plastic part of the hinge.
    Ask FixBot
11 other people completed this guide.
Val
1,227 Reputation
6 Guides authored
9 Guide Comments
Hello. Any idea where can i buy the folding hinge from? thx!
Liviu - Reply Share
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
Menno de Gier - Reply Share
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
Eatfire - Reply Share
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
https://guide-images.cdn.ifixit.com/igi/...
Cus7od35 - Reply Share
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 136
All Time: 13,531
