Skullcandy Crusher Wireless Battery Replacement
Views: 16K
View statistics:
Past 24 Hours:
8
Past 7 Days:
52
Past 30 Days:
230
All Time:
16,284
Comments: 11
6 comments on steps, 5 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 50 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Use this guide to replace the battery in a Skullcandy Crusher Wireless headphones. A replacement battery can be bought online.
Follow this replacement guide if you've identified the battery as a source of the problem (or maybe you just want to see the internal components of your Skullcandy Crusher Wireless). To be sure, check out the Troubleshooting page.
Make sure you are not working with a swollen battery.
Also, for more information about soldering and desoldering, please use this guide.
Parts
Tools
    1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: step 1, image 1 of 2 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: step 1, image 2 of 2
      • Take your headphones and hold them upside down for better control with your hands.
      Ask FixBot
    2. Skullcandy Crusher Wireless Battery Replacement: step 2, image 1 of 2 Skullcandy Crusher Wireless Battery Replacement: step 2, image 2 of 2
      • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
      • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
      Ask FixBot
    3. Skullcandy Crusher Wireless Battery Replacement: step 3, image 1 of 1
      • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
      Ask FixBot
    1. Skullcandy Crusher Wireless Battery Replacement, Battery: step 4, image 1 of 2 Skullcandy Crusher Wireless Battery Replacement, Battery: step 4, image 2 of 2
      • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
      • You have to work on the right-side earphone.
      Ask FixBot
    2. Skullcandy Crusher Wireless Battery Replacement: step 5, image 1 of 3 Skullcandy Crusher Wireless Battery Replacement: step 5, image 2 of 3 Skullcandy Crusher Wireless Battery Replacement: step 5, image 3 of 3
      • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
      • Gently pry the speaker part away from the frame of the headphones.
      Ask FixBot
    3. Skullcandy Crusher Wireless Battery Replacement: step 6, image 1 of 2 Skullcandy Crusher Wireless Battery Replacement: step 6, image 2 of 2
      • Separate the headphone speaker assembly from the headphone speaker frame.
      Ask FixBot
    4. Skullcandy Crusher Wireless Battery Replacement: step 7, image 1 of 3 Skullcandy Crusher Wireless Battery Replacement: step 7, image 2 of 3 Skullcandy Crusher Wireless Battery Replacement: step 7, image 3 of 3
      • Remove the battery from the headphone housing.
      • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
      • For more information on soldering, please, use this Solder and Desolder Connections guide.
      Ask FixBot
6 other people completed this guide.
Val
1,227 Reputation
6 Guides authored
5 Guide Comments
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Reply Share
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen - Reply Share
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Reply Share
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Reply Share
Am I able to send my headphones to you to be fixed?
If I can, what would the cost be?
I have two headphone sets
Jeffrey Timothy Valerie - Reply Share
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 230
All Time: 16,284
