Skullcandy Air Raid Speakers Replacement
    1. Skullcandy Air Raid Speakers Replacement, Rubber Cover: step 1, image 1 of 1
      • Starting with the corners, gently pull the rubber cover off of the device.
      Ask FixBot
    2. Skullcandy Air Raid Speakers Replacement, Handle: step 2, image 1 of 1
      • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
      • Remove the handle from the device.
      Ask FixBot
    3. Skullcandy Air Raid Speakers Replacement, Front Plate: step 3, image 1 of 1
      • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
      • One 5mm Phillips screw.
      • One 8mm Phillips screw.
      Ask FixBot
    4. Skullcandy Air Raid Speakers Replacement: step 4, image 1 of 1
      • Gently pull the sides of the front plate outwards from the device.
      • Pull up on the front plate to remove it from the device.
      Ask FixBot
    1. Skullcandy Air Raid Speakers Replacement, Speakers: step 5, image 1 of 1
      • Using a #000 Phillips Screwdriver, unscrew the four 0.8 cm Philips screws from each corner of the speaker you are replacing (eight 0.8 Philips screws total).
      Ask FixBot
    2. Skullcandy Air Raid Speakers Replacement: step 6, image 1 of 1
      • Using the plastic opening tool, pry around edges of speaker to loosen glue contact with front plate.
      • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
      Ask FixBot
    3. Skullcandy Air Raid Speakers Replacement: step 7, image 1 of 1
      • Lift the speaker out of the device.
      • Be aware of the connection with the ribbon cable.
      • For reassembly, ensure proper orientation of the cable plug.
      Ask FixBot
    4. Skullcandy Air Raid Speakers Replacement: step 8, image 1 of 1
      • Firmly pull on the end of the ribbon cable to disconnect the speaker from the motherboard.
      Ask FixBot
    5. Skullcandy Air Raid Speakers Replacement, Desolder Wires: step 9, image 1 of 1
      • Desolder the black and red wires from the speaker.
      • The red wire is for the left speaker and the black is for the right speaker.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Where can I buy the replacement speaker?
Luis Polino - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 2,021
