Skullcandy Air Raid Motherboard Replacement
    1. Skullcandy Air Raid Motherboard Replacement, Rubber Cover: step 1, image 1 of 1
      • Starting with the corners, gently pull the rubber cover off of the device.
      Ask FixBot
    2. Skullcandy Air Raid Motherboard Replacement, Handle: step 2, image 1 of 1
      • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
      • Remove the handle from the device.
      Ask FixBot
    3. Skullcandy Air Raid Motherboard Replacement, Front Plate: step 3, image 1 of 1
      • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
      • One 5mm Phillips screw.
      • One 8mm Phillips screw.
      Ask FixBot
    4. Skullcandy Air Raid Motherboard Replacement: step 4, image 1 of 1
      • Gently pull the sides of the front plate outwards from the device.
      • Pull up on the front plate to remove it from the device.
      Ask FixBot
    1. Skullcandy Air Raid Motherboard Replacement, Speakers: step 5, image 1 of 1
      • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
      Ask FixBot
    2. Skullcandy Air Raid Motherboard Replacement: step 6, image 1 of 1
      • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
      • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
      Ask FixBot
    3. Skullcandy Air Raid Motherboard Replacement: step 7, image 1 of 1
      • Lift the speaker out of the device.
      • Be aware of the connection with the ribbon cable.
      • For reassembly, ensure proper orientation of the cable plug.
      Ask FixBot
    4. Skullcandy Air Raid Motherboard Replacement: step 8, image 1 of 1
      • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
      Ask FixBot
    5. Skullcandy Air Raid Motherboard Replacement, Control Buttons: step 9, image 1 of 1
      • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
      Ask FixBot
    6. Skullcandy Air Raid Motherboard Replacement: step 10, image 1 of 1
      • Lift the button panel.
      Ask FixBot
    7. Skullcandy Air Raid Motherboard Replacement, Button Motherboard: step 11, image 1 of 1
      • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
      Ask FixBot
    8. Skullcandy Air Raid Motherboard Replacement: step 12, image 1 of 1
      • Using a plastic opening tool, pry the button motherboard to detach it from the device.
      • The button motherboard is connected to a ribbon cable inside the device.
      Ask FixBot
    9. Skullcandy Air Raid Motherboard Replacement, Ribbon Cable: step 13, image 1 of 1
      • Pull the black ribbon cord attachment away from the motherboard.
      • Pull on the cable until it releases from the back of the motherboard.
      • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
      Ask FixBot
    10. Skullcandy Air Raid Motherboard Replacement, Back panel: step 14, image 1 of 2 Skullcandy Air Raid Motherboard Replacement, Back panel: step 14, image 2 of 2
      • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
      • Lift off the back panel.
      Ask FixBot
    1. Skullcandy Air Raid Motherboard Replacement, Battery and USB Port Cables: step 15, image 1 of 1
      • Pull the black piece of the USB port ribbon cable connector away from the motherboard.
      • Pull the ribbon cable out of the connector.
      Ask FixBot
    2. Skullcandy Air Raid Motherboard Replacement: step 16, image 1 of 1
      • Pull the USB power cable away from the motherboard to disconnect it.
      • Pull the battery power cable away from the motherboard to disconnect it.
      Ask FixBot
    3. Skullcandy Air Raid Motherboard Replacement, Motherboard: step 17, image 1 of 1
      • Pull up on the motherboard from both sides.
      Ask FixBot
1 Guide Comment
I need a new motherboard. Front and rear. Can I order one?
Nick Fines - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,981
