Up to 20% off select tools
Skullcandy Air Raid Buttons Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
100
All Time:
1,962
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This disassembly includes the button panel and button motherboard.
    1. Skullcandy Air Raid Buttons Replacement, Rubber Cover: step 1, image 1 of 1
      • Starting with the corners, gently pull the rubber cover off of the device.
      Ask FixBot
    2. Skullcandy Air Raid Buttons Replacement, Handle: step 2, image 1 of 1
      • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
      • Remove the handle from the device.
      Ask FixBot
    3. Skullcandy Air Raid Buttons Replacement, Front Plate: step 3, image 1 of 1
      • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
      • One 5mm Phillips screw.
      • One 8mm Phillips screw.
      Ask FixBot
    4. Skullcandy Air Raid Buttons Replacement: step 4, image 1 of 1
      • Gently pull the sides of the front plate outwards from the device.
      • Pull up on the front plate to remove it from the device.
      Ask FixBot
    1. Skullcandy Air Raid Buttons Replacement, Control Buttons: step 5, image 1 of 2 Skullcandy Air Raid Buttons Replacement, Control Buttons: step 5, image 2 of 2
      • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
      • Lift the button panel.
      Ask FixBot
    2. Skullcandy Air Raid Buttons Replacement, Button Motherboard: step 6, image 1 of 1
      • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
      Ask FixBot
    3. Skullcandy Air Raid Buttons Replacement: step 7, image 1 of 1
      • Using a plastic opening tool, pry up on the button motherboard to detach it from the device.
      • The button motherboard is connected to a ribbon cable inside the device.
      Ask FixBot
    4. Skullcandy Air Raid Buttons Replacement, Ribbon Cable: step 8, image 1 of 1
      • First, pull on the black attachment to disconnect it from the metal piece.
      • Release the cable from the back of the motherboard.
      • The black attachment is a part of the connector, not the blue ribbon cable. It will not disconnect from the motherboard.
      Ask FixBot
2 other people completed this guide.
Author
with
Sasha Nevin
257 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 100
All Time: 1,962
