SkullCandy Hesh Size Adjuster Replacement
    1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: step 1, image 1 of 2 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: step 1, image 2 of 2
      • Locate the break in the device.
      Ask FixBot
    2. SkullCandy Hesh Size Adjuster Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
      Ask FixBot
    3. SkullCandy Hesh Size Adjuster Replacement: step 3, image 1 of 1
      • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
      Ask FixBot
    4. SkullCandy Hesh Size Adjuster Replacement: step 4, image 1 of 2 SkullCandy Hesh Size Adjuster Replacement: step 4, image 2 of 2
      • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
      Ask FixBot
    5. SkullCandy Hesh Size Adjuster Replacement: step 5, image 1 of 1
      • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
      Ask FixBot
    6. SkullCandy Hesh Size Adjuster Replacement: step 6, image 1 of 1
      • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
      Ask FixBot
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
247 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,311
