SkullCandy Hesh Auxiliary Cable Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
1,675
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
In the case of a severed or frayed auxiliary cable, replacements can be purchased or salvaged from another broken device. This guide will show users how to replace it temporarily, without the use of a soldering gun.
Tools
    1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: step 1, image 1 of 1
      • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
      Ask FixBot
    2. SkullCandy Hesh Auxiliary Cable Replacement: step 2, image 1 of 1
      • Using wire cutters, cut the auxiliary cable at the determined damaged area.
      • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
      Ask FixBot
    3. SkullCandy Hesh Auxiliary Cable Replacement: step 3, image 1 of 2 SkullCandy Hesh Auxiliary Cable Replacement: step 3, image 2 of 2
      • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
      Ask FixBot
    4. SkullCandy Hesh Auxiliary Cable Replacement: step 4, image 1 of 1
      • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
      • Twist together the same colored wires from the device cable and the new cable.
      Ask FixBot
    5. SkullCandy Hesh Auxiliary Cable Replacement: step 5, image 1 of 1
      • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
      Ask FixBot
    6. SkullCandy Hesh Auxiliary Cable Replacement: step 6, image 1 of 1
      • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
      Ask FixBot
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
Sarah Burk
247 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 1,675
