Skull Candy Grind Fuel Cover Close Detector Fix
    1. Skull Candy Grind Fuel Cover Close Detector Fix, Magnet!: step 1, image 1 of 1
      • The magnet is on the dimpled part of the case, which closes right behind the earbuds and actuates some sort of sensor that tells the case the cover is closed.
      Ask FixBot
      • The fix is to use a spudger, opening tool or (if you’re desperate like me) a screwdriver to pry the orange piece off. Then you can recover the loose magnet, superglue it back into the obvious slot for it, and snap the case together.
      Ask FixBot
Hopefully polarity won’t matter, I didn’t test that.
Neal Sofge
153 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 23
