Up to 20% off select tools
Skateboard Pivot Cup Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
97
All Time:
2,699
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
When wear and tear settle in, pivot cups can produce an annoying squeaking sound, in addition to negatively affecting the performance of skateboard trucks. Replacing a damaged pivot cup is a relatively fast and simple process that can be accomplished anywhere if you have the correct tools.
This guide will demonstrate how to replace the pivot cups on your skateboard, and enjoy a squeak-free ride once again.
    1. Skateboard Pivot Cup Replacement, Pivot Cups: step 1, image 1 of 2 Skateboard Pivot Cup Replacement, Pivot Cups: step 1, image 2 of 2
      • Remove the nut from the kingpin.
      Ask FixBot
    2. Skateboard Pivot Cup Replacement: step 2, image 1 of 3 Skateboard Pivot Cup Replacement: step 2, image 2 of 3 Skateboard Pivot Cup Replacement: step 2, image 3 of 3
      • Pull off the truck hanger and remove the bushings and washers.
      Ask FixBot
    3. Skateboard Pivot Cup Replacement: step 3, image 1 of 1
      • Place your free hand a safe distance from the screwdriver in case it slips.
      • Wedge the screwdriver into the side of the pivot cup and raise the edge.
      Ask FixBot
    4. Skateboard Pivot Cup Replacement: step 4, image 1 of 2 Skateboard Pivot Cup Replacement: step 4, image 2 of 2
      • Grab the edge of the pivot cup with pliers and pull the pivot cup all the way out.
      Ask FixBot
    5. Skateboard Pivot Cup Replacement: step 5, image 1 of 1
      • Insert your new pivot cup into the hole.
      Ask FixBot
    6. Skateboard Pivot Cup Replacement: step 6, image 1 of 3 Skateboard Pivot Cup Replacement: step 6, image 2 of 3 Skateboard Pivot Cup Replacement: step 6, image 3 of 3
      • Put the parts of the truck back in place.
      Ask FixBot
Enjoy the smooth ride!
Author
with
José Torres
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 97
All Time: 2,699
