Sirius Stiletto 2 Scroll Wheel Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
80
All Time:
772
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The scroll wheels allows user interact with the device. A scroll wheel that does not work will not allow users to play music or access other features on the device.
Tools
    1. Sirius Stiletto 2 Scroll Wheel Replacement, Battery: step 1, image 1 of 1
      • From the back of the device, slide the back panel downwards to unlock the panel.
      • Lift the panel up, exposing the battery.
      Ask FixBot
    2. Sirius Stiletto 2 Scroll Wheel Replacement: step 2, image 1 of 2 Sirius Stiletto 2 Scroll Wheel Replacement: step 2, image 2 of 2
      • Pinch the battery from both sides and lift the battery to remove it.
      Ask FixBot
    1. Sirius Stiletto 2 Scroll Wheel Replacement, Front Cover: step 3, image 1 of 1
      • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
      • If needed, remove the sticker to see the screws
      Ask FixBot
    2. Sirius Stiletto 2 Scroll Wheel Replacement: step 4, image 1 of 2 Sirius Stiletto 2 Scroll Wheel Replacement: step 4, image 2 of 2
      • Start by using a plastic opening tool to loosen the front cover from the sides.
      • Work your way to the bottom of the cover then the top.
      • Carefully pry the front cover off.
      Ask FixBot
    1. Sirius Stiletto 2 Scroll Wheel Replacement, Scroll Wheel: step 5, image 1 of 2 Sirius Stiletto 2 Scroll Wheel Replacement, Scroll Wheel: step 5, image 2 of 2
      • Isolate the scroll wheel assembly
      • Gently pry the four metal tabs outwards, away from the scroll pad.
      Ask FixBot
    2. Sirius Stiletto 2 Scroll Wheel Replacement: step 6, image 1 of 1
      • Once the scroll pad has been released, be careful not to drop the center button. This may damage the spring.
      Ask FixBot
Benjamin Her
567 Reputation
5 Guides authored
USF Tampa, Team 6-6, Brown Winter 2015 Member of USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 80
All Time: 772
