Sirius Stiletto 2 LCD Display Replacement
  1. Sirius Stiletto 2 LCD Display Replacement, Battery: step 1, image 1 of 1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
    Ask FixBot
  2. Sirius Stiletto 2 LCD Display Replacement: step 2, image 1 of 2 Sirius Stiletto 2 LCD Display Replacement: step 2, image 2 of 2
    • Pinch the battery from both sides and lift the battery to remove it.
    Ask FixBot
  3. Sirius Stiletto 2 LCD Display Replacement, Front Cover: step 3, image 1 of 1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
    Ask FixBot
  4. Sirius Stiletto 2 LCD Display Replacement: step 4, image 1 of 2 Sirius Stiletto 2 LCD Display Replacement: step 4, image 2 of 2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
    Ask FixBot
  5. Sirius Stiletto 2 LCD Display Replacement, LCD Display: step 5, image 1 of 1
    • Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
    Ask FixBot
  6. Sirius Stiletto 2 LCD Display Replacement: step 6, image 1 of 2 Sirius Stiletto 2 LCD Display Replacement: step 6, image 2 of 2
    • Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
    Ask FixBot
  7. Sirius Stiletto 2 LCD Display Replacement: step 7, image 1 of 1
    • LCD display (left).
    Ask FixBot
Benjamin Her
567 Reputation
5 Guides authored
USF Tampa, Team 6-6, Brown Winter 2015 Member of USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 19
All Time: 647
