Introduction
Go to step 1 ↓A leaky sink can be a common household annoyance, often caused by worn or damaged O-rings. O-rings are small rubber or silicone seals that prevent water from escaping where parts of your sink assembly connect. Over time, these rings can deteriorate due to wear, water pressure, or exposure to cleaning agents, leading to drips, reduced water efficiency, and even potential damage to surrounding areas.
Replacing an O-ring is an essential, cost-effective maintenance task that can save you money on water bills and prevent more extensive plumbing issues. This guide will walk you through the step-by-step process of identifying the problem, removing the old O-ring, and installing a new one, ensuring your sink operates as good as new. With just a few tools and a little patience, you can restore your sink’s functionality in no time!
Locate both valves for hot and cold water. These are typically under the sink.
Turn off the water supply by turning each knob clockwise to stop the flow of water.
