Sink Drain Pop-Up Stopper Replacement
    1. Sink Drain Pop-Up Stopper Replacement, Pop-Up Stopper: step 1, image 1 of 2 Sink Drain Pop-Up Stopper Replacement, Pop-Up Stopper: step 1, image 2 of 2
      • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
      • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
      Ask FixBot
    2. Sink Drain Pop-Up Stopper Replacement: step 2, image 1 of 1
      • Disconnect the pivot rod from the center pop-up extension.
      Ask FixBot
    3. Sink Drain Pop-Up Stopper Replacement: step 3, image 1 of 2 Sink Drain Pop-Up Stopper Replacement: step 3, image 2 of 2
      • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
      Ask FixBot
    4. Sink Drain Pop-Up Stopper Replacement: step 4, image 1 of 3 Sink Drain Pop-Up Stopper Replacement: step 4, image 2 of 3 Sink Drain Pop-Up Stopper Replacement: step 4, image 3 of 3
      • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
      Ask FixBot
    5. Sink Drain Pop-Up Stopper Replacement: step 5, image 1 of 2 Sink Drain Pop-Up Stopper Replacement: step 5, image 2 of 2
      • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
      Ask FixBot
    6. Sink Drain Pop-Up Stopper Replacement: step 6, image 1 of 2 Sink Drain Pop-Up Stopper Replacement: step 6, image 2 of 2
      • In the sink, the pop-up stopper will be loose.
      • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 142
Past 30 Days: 620
All Time: 3,741
