Singing Machine Shine Duets Motherboard Replacement
  1. Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 1 of 3 Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 2 of 3 Singing Machine Shine Duets Motherboard Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 3 of 3
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
    Ask FixBot
  2. Singing Machine Shine Duets Motherboard Replacement: step 2, image 1 of 3 Singing Machine Shine Duets Motherboard Replacement: step 2, image 2 of 3 Singing Machine Shine Duets Motherboard Replacement: step 2, image 3 of 3
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  3. Singing Machine Shine Duets Motherboard Replacement: step 3, image 1 of 3 Singing Machine Shine Duets Motherboard Replacement: step 3, image 2 of 3 Singing Machine Shine Duets Motherboard Replacement: step 3, image 3 of 3
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
    Ask FixBot
  4. Singing Machine Shine Duets Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • The motherboard is located right behind the control buttons.
    Ask FixBot
  5. Singing Machine Shine Duets Motherboard Replacement: step 5, image 1 of 2 Singing Machine Shine Duets Motherboard Replacement: step 5, image 2 of 2
    • Remove the two screws holding the LED board in place.
    Ask FixBot
  6. Singing Machine Shine Duets Motherboard Replacement: step 6, image 1 of 2 Singing Machine Shine Duets Motherboard Replacement: step 6, image 2 of 2
    • Remove both LED boards from their pins.
    Ask FixBot
  7. Singing Machine Shine Duets Motherboard Replacement: step 7, image 1 of 2 Singing Machine Shine Duets Motherboard Replacement: step 7, image 2 of 2
    • Detach the white cable from its connector on the motherboard.
    Ask FixBot
  8. Singing Machine Shine Duets Motherboard Replacement: step 8, image 1 of 2 Singing Machine Shine Duets Motherboard Replacement: step 8, image 2 of 2
    • Carefully disconnect this red-and-black wire from the motherboard.
    Ask FixBot
  9. Singing Machine Shine Duets Motherboard Replacement: step 9, image 1 of 2 Singing Machine Shine Duets Motherboard Replacement: step 9, image 2 of 2
    • Remove the thicker red-and-black wire from its socket on the motherboard.
    Ask FixBot
  10. Singing Machine Shine Duets Motherboard Replacement: step 10, image 1 of 3 Singing Machine Shine Duets Motherboard Replacement: step 10, image 2 of 3 Singing Machine Shine Duets Motherboard Replacement: step 10, image 3 of 3
    • Disconnect the red port on the board which holds all of the external plugs
    • Disconnect the white wires from the board.
    Ask FixBot
  11. Singing Machine Shine Duets Motherboard Replacement: step 11, image 1 of 2 Singing Machine Shine Duets Motherboard Replacement: step 11, image 2 of 2
    • Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
    Ask FixBot
  12. Singing Machine Shine Duets Motherboard Replacement: step 12, image 1 of 3 Singing Machine Shine Duets Motherboard Replacement: step 12, image 2 of 3 Singing Machine Shine Duets Motherboard Replacement: step 12, image 3 of 3
    • Remove the motherboard from the shell.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 30
All Time: 638
