Singing Machine Shine Duets LED Lights Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
46
All Time:
479
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Singing Machine Shine Duets karaoke machine's LED lights are not functioning on one or more sides, access the LED board and motherboard by following our guide. Because the LED board needs to be connected to the device by pins and a screw, you will need to attach/reattach it using our guide. This repair is not particularly difficult, but it will require some relatively forceful part separation, so be careful and methodical.
Tools
    1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 3 of 3
      • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
      Ask FixBot
    2. Singing Machine Shine Duets LED Lights Replacement: step 2, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement: step 2, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement: step 2, image 3 of 3
      • Remove the three 8 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    3. Singing Machine Shine Duets LED Lights Replacement: step 3, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement: step 3, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement: step 3, image 3 of 3
      • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
      • The top portion of the shell is open, and the inside of the device is now accessible.
      Ask FixBot
    1. Singing Machine Shine Duets LED Lights Replacement, LED Lights: step 4, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: step 4, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: step 4, image 3 of 3
      • Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
      Ask FixBot
    2. Singing Machine Shine Duets LED Lights Replacement: step 5, image 1 of 3 Singing Machine Shine Duets LED Lights Replacement: step 5, image 2 of 3 Singing Machine Shine Duets LED Lights Replacement: step 5, image 3 of 3
      • Carefully remove the lightboard from the device, taking care not to damage any pins.
      • To reassemble, connect the pins on the lightboard to the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 46
All Time: 479
