Singing Machine Shine Duets Audio/Power Jack Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
43
All Time:
1,330
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your Singing Machine Shine Duets audio or power jacks are not functioning, use this guide as a means to replace it. If any parts which are removed in this guide have glue on them, use a metal scraping device to remove it. For our purposes, tweezers were sufficient.
Tools
    1. Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 1 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 2 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: step 1, image 3 of 3
      • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
      Ask FixBot
    2. Singing Machine Shine Duets Audio/Power Jack Replacement: step 2, image 1 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 2, image 2 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 2, image 3 of 3
      • Remove the three 8 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    3. Singing Machine Shine Duets Audio/Power Jack Replacement: step 3, image 1 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 3, image 2 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 3, image 3 of 3
      • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
      • The top portion of the shell is open, and the inside of the device is now accessible.
      Ask FixBot
    1. Singing Machine Shine Duets Audio/Power Jack Replacement, Motherboard: step 4, image 1 of 1
      • The motherboard is located right behind the control buttons.
      Ask FixBot
    2. Singing Machine Shine Duets Audio/Power Jack Replacement: step 5, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 5, image 2 of 2
      • Remove the two screws holding the LED board in place.
      Ask FixBot
    3. Singing Machine Shine Duets Audio/Power Jack Replacement: step 6, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 6, image 2 of 2
      • Remove both LED boards from their pins.
      Ask FixBot
    4. Singing Machine Shine Duets Audio/Power Jack Replacement: step 7, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 7, image 2 of 2
      • Detach the white cable from its connector on the motherboard.
      Ask FixBot
    5. Singing Machine Shine Duets Audio/Power Jack Replacement: step 8, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 8, image 2 of 2
      • Carefully disconnect this red-and-black wire from the motherboard.
      Ask FixBot
    6. Singing Machine Shine Duets Audio/Power Jack Replacement: step 9, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 9, image 2 of 2
      • Remove the thicker red-and-black wire from its socket on the motherboard.
      Ask FixBot
    7. Singing Machine Shine Duets Audio/Power Jack Replacement: step 10, image 1 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 10, image 2 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 10, image 3 of 3
      • Disconnect the red port on the board which holds all of the external plugs
      • Disconnect the white wires from the board.
      Ask FixBot
    8. Singing Machine Shine Duets Audio/Power Jack Replacement: step 11, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 11, image 2 of 2
      • Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
      Ask FixBot
    9. Singing Machine Shine Duets Audio/Power Jack Replacement: step 12, image 1 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 12, image 2 of 3 Singing Machine Shine Duets Audio/Power Jack Replacement: step 12, image 3 of 3
      • Remove the motherboard from the shell.
      Ask FixBot
    1. Singing Machine Shine Duets Audio/Power Jack Replacement, Audio/Power Jack: step 13, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement, Audio/Power Jack: step 13, image 2 of 2
      • Remove both screws from the board.
      • Use caution when removing the screw in between the two ports.
      Ask FixBot
    2. Singing Machine Shine Duets Audio/Power Jack Replacement: step 14, image 1 of 2 Singing Machine Shine Duets Audio/Power Jack Replacement: step 14, image 2 of 2
      • Remove the board from the shell.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 43
All Time: 1,330
