Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Singer Europa 100 Disassembly
Views: 4.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
149
All Time:
4,120
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows how to remove the various plastic panels from a Singer Europa 100 sewing machine in order to access its internal components. Unplug the machine before you begin.
      • Dismantle the main case
      Ask FixBot
    1. Singer Europa 100 Disassembly: step 2, image 1 of 1
      • Remove this screw completely. This will allow you to remove the plastic cover
      Ask FixBot
    2. Singer Europa 100 Disassembly: step 3, image 1 of 2 Singer Europa 100 Disassembly: step 3, image 2 of 2
      • Remove these two pins that hold the plastic shell on
      Ask FixBot
    3. Singer Europa 100 Disassembly: step 4, image 1 of 2 Singer Europa 100 Disassembly: step 4, image 2 of 2
      • Remove all clips and separate shell
      • Remove cover
      Ask FixBot
To reassemble your device, follow these instructions in reverse order
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Bossard Nicolas
1,341 Reputation
6 Guides authored
1 Guide Comment
Merci beaucoup pour ce tutoriel qui m'a été très utile. Un complément sur le démontage de la façade du tenseur de la singer Europa 100 serait fantastique :) Je suis en effet bloquée car je ne trouve pas de moyen pour retirer ce capot et le curseur du tenseur est bloqué en position haute, je ne peux pas accéder au tenseur lui-même pour identifier le problème... Merci beaucoup
Joelle Torta - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 149
All Time: 4,120
