This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓This guide will show you have to disassemble your device/tool
Disassemble the screw that fixes the hood.
Disassemble the plate under the needle.
Disassemble the foot that contains the can.
Remove the side screws.
Remove the screws from the bottom (the upper left foot is also a screw).
Gently unclip the plastic cover.
If the motor and/or the white wheel at the end no longer drives the main axis (and therefore at the end, no longer drives the needle)...
... it is then necessary to tighten the screw of the wheel, so that the whole no longer patinates.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
