This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Although commercial 1.5 V battery testers exist for AA, AAA, and D battery sizes, making a homemade tester was a challenge; building one for just 1 battery was not possible for me, since a discharged 1.5 V battery (less than 1.15 V) cannot light up an LED of any of the colors I have tested.
So I had no choice but to use 2 batteries in a radio battery holder; by soldering 2 alligator clips to this same holder, we also have a homemade repair tool for disassembling and repairing remote controls.
Example of connecting the battery holder to the tester circuit.
2 batteries in good condition measure between 2.85 and 3 V and light the LED at almost 100%; the idea of this circuit is to push the LED's lighting to the limit, so that in the event of a voltage drop, the LED tends to dim or turn off.
In the event of a dim or off LED, we could perform a second check: by removing the diode on the right side, we can connect between the 2 diodes, so the circuit will light up with less voltage. This would be an auxiliary check.
I must say that this is not one of the designs I liked the most, nor one of the most complete, but building a tester for 1.5 V batteries was a challenge after seeing the problems there were with lighting up LEDs of different colors; in the end, I made it with a Blue LED.
Other Guides dedicated to battery testers: Electronics Skills
END of the Guide.
