Community-Contributed Guide
Introduction
Go to step 1 ↓Ventilation and solar panel makes the Soil Pro extra great, that’s why we call it the Soil Pro plus (+)
Tools
PCB RR02 or higher 'coated
Sigrow Soil Sensor
(Top left to bottom right) Case Body +, hat +, solar, bottom inner plate +, fan holder.
Sunon Fan 5VDC
Solar panel 110x80
Tools (top-left to bottom right) : tin, soldering station, flat head screw driver, cable peeler, pliers glue gun (optional).
Cable double insulaton: +6 wires, 20 cm
Cable length is aprox 20-22 cm
Peel both ends, keep the non-peeled part short
Group them, twist and solder them together
On the opposite side you will only keep two colours: black and yellow
From top to bottom:
Solar Panel mounted and with cable soldered (side with Sigrow letters)
Fan (cable enters from bottom)
Soil Sensor (cable enters from Sigrow 3 circles logo side)
Fan holder should be inserted in main body case by pressure
Option 1: Request a new fan holder
Option 2: Use the hot glue gun.
tight fit could be interpreted as: "if with very hard shaken the fan holder and main case will not disconnect and stay solidly attached.'
Insert cables into connector, check in 3rd image in this step that the ports are open
Use pliers to cut white cable
Yellow is positive
Black is negative (closer to the edge)
It's great to leave some extra cables in good shape
~10 cm for the soil sensor bended as inverted-U
Twist the fan cable (it's very long) and bend as inverted-U
In case of doubt contact manufacturing@sigrow.com
