Signode BXT3-16 Strapping Combo Tool Spring Replacement
    1. Signode BXT3-16 Strapping Combo Tool Spring Replacement, Spring: step 1, image 1 of 1
      • Before dismantling the strapping gun, ensure the power source / battery is removed.
      Ask FixBot
    2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 2, image 1 of 1
      • Turn the strapping gun upside down.
      • Place it on a flat surface to keep the strapping gun stable during repair.
      • There are four Torx T4 screws on the bottom of the tool.
      Ask FixBot
    3. Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 3, image 1 of 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 3, image 2 of 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 3, image 3 of 3
      • Use the Torx T4 screwdriver to remove the four 25 mm screws from the base plate.
      • Remove the single 25 mm Torx T4 screw from the front side of the strapping gun.
      • Use a Torx T4 screwdriver to remove the two 25 mm screws on the front of the tool.
      Ask FixBot
    4. Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 4, image 1 of 1
      • Rotate the strapping gun to the opposite side.
      • Use the Torx T4 screwdriver to remove the remaining 25 mm screws from the front of the strapping gun.
      Ask FixBot
    5. Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 5, image 1 of 2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 5, image 2 of 2
      • Rotate the strapping tool to the original position, with the model number and name facing you.
      • Firmly pull the guard plate and the tool apart using both hands.
      Ask FixBot
    6. Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 6, image 1 of 2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 6, image 2 of 2
      • Use a metal spudger to lift the cutter.
      • Gently, push the spring out from the bottom of the base of the strapping gun.
      Ask FixBot
    7. Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 7, image 1 of 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 7, image 2 of 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: step 7, image 3 of 3
      • Rotate the machine to remove the spring gently by hand.
      • Remove the spring from the base of the strapping tool.
      • Replace with new spring by inserting it the same way it was removed.
      Ask FixBot
3 other people completed this guide.
Jainam Shah
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 42
All Time: 1,190
