Siemens-Maquet Servo-i Battery Module Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    • Check the battery date. The battery needs replacing after 3 years.
    • The manufacturing date is listed in the format (year-week) on the battery label.
    • Servo-i User Manual page 19.
    Ask FixBot
    • If battery status on touchpad display is red make sure to replace battery modules.
    • At least one battery module must be installed at all times. If not the ventilator will not work properly.
    • Store uninstalled batteries at 15-20 degrees celsius.
    Ask FixBot
  1. Siemens-Maquet Servo-i Battery Module Replacement: step 3, image 1 of 1
    • Wait for the battery to be fully charged.
    • To check this, press the battery power symbol button on the battery.
    • All four LED's must be lit.
    • Servo-i User Manual page 20.
    Ask FixBot
  2. Siemens-Maquet Servo-i Battery Module Replacement: step 4, image 1 of 1
    • With gas, patient tubes and test lung connected, let the Servo-i run in a ventilation mode.
    • Disconnect mains power to the unit to allow battery operation.
    • Allow ventilator to run and make sure 'No battery capacity'- alarm is not activated.
    • Servo-i Service Manual 5-2.
    Ask FixBot
  3. Siemens-Maquet Servo-i Battery Module Replacement: step 5, image 1 of 1
    • The time between the 'Limited battery capacity'- alarm and the 'No battery capacity' alarm must not exceed 7 minutes.
    • The event log contains the records of alarm times.
    Ask FixBot
  4. Siemens-Maquet Servo-i Battery Module Replacement: step 6, image 1 of 3 Siemens-Maquet Servo-i Battery Module Replacement: step 6, image 2 of 3 Siemens-Maquet Servo-i Battery Module Replacement: step 6, image 3 of 3
    • See if the upper part of the module is equipped with a latch. This means it is fixed and follow these instructions to disassemble a battery from the battery module.
    • 1. Locate a small hexagonal wrench or screwdriver.
    • Place the tool in the small hole on the right hand side.
    • 2. Simultaneously push the release button.
    • 3. Remove the tool, while still pressing the release button.
    • 4. Continue to keep the button pressed until the battery pops out.
    • 5. Pull out the battery module.
    • Servo-i Service Manual 4-18.
    Ask FixBot
Monroe Erle
133 Reputation
1 Guide authored
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G2, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G2
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 39
All Time: 1,535
