This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Siemens EQ500 Test Mode
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
44
Past 30 Days:
221
All Time:
1,361
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Using the test mode, you can test important device functions (sensors, display, lighting, motor, pump, heater). You can read out statistics, data, and the error log. The menu navigation is in English and largely self-explanatory.
    1. Siemens EQ500 Test Mode, Siemens EQ500 Test Mode: step 1, image 1 of 2 Siemens EQ500 Test Mode, Siemens EQ500 Test Mode: step 1, image 2 of 2
      • The device must be switched off.
      • Switch on the device. Then immediately—at the latest right after the beep—press and hold the buttons for Espresso and Latte macchiato simultaneously. The machine will enter test mode immediately.
      Ask FixBot
    2. Siemens EQ500 Test Mode: step 2, image 1 of 3 Siemens EQ500 Test Mode: step 2, image 2 of 3 Siemens EQ500 Test Mode: step 2, image 3 of 3
      • The selection is made on the display. Use the four faintly lit areas to the left and right of the display to navigate. The selection points are mostly self-explanatory.
      • First area on the right: Navigate down
      • Second area on the right: Confirm selection
      • First area on the left: Navigate up
      • Second area on the left: Cancel menu item
      • Press the power button to exit test mode.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
VauWeh
344,639 Reputation
317 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 221
All Time: 1,361
