Up to 20% off select tools
Siemens A56 Keyboard Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
87
All Time:
954
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Siemens A56 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Press down on the grooved area firmly in the direction of arrow #1.
      • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
      • Photos taken from: http://theinformr.com/uploads/manuals/si...
      Ask FixBot
    2. Siemens A56 Keyboard Replacement: step 2, image 1 of 1
      • Turn off the phone before removing the battery to avoid damage.
      • Press the latch on the battery in the direction of arrow #3.
      • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
      • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
      Ask FixBot
    1. Siemens A56 Keyboard Replacement, Front Plate: step 3, image 1 of 3 Siemens A56 Keyboard Replacement, Front Plate: step 3, image 2 of 3 Siemens A56 Keyboard Replacement, Front Plate: step 3, image 3 of 3
      • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
      • Pull up on the two plastic clips at the top of the phone.
      • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
      Ask FixBot
    1. Siemens A56 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Siemens A56 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Siemens A56 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • The keyboard can be easily removed by hand.
      • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
      Ask FixBot
Author
with
Andrew Corriveau
97 Reputation
1 Guide authored
Clemson, Team 6-6, Benson Spring 2014 Member of Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 87
All Time: 954
