Up to 20% off select tools
Sidekick II Outer Casing Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
85
All Time:
3,252
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Taking apart the outside casing.
    1. Sidekick II Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
      • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
      • Gently pry open button and remove button.
      • Do this for each of the 3 buttons remaining.
      Ask FixBot
    2. Sidekick II Outer Casing Replacement: step 2, image 1 of 2 Sidekick II Outer Casing Replacement: step 2, image 2 of 2
      • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
      Ask FixBot
    3. Sidekick II Outer Casing Replacement: step 3, image 1 of 1
      • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
      Ask FixBot
    4. Sidekick II Outer Casing Replacement: step 4, image 1 of 1
      • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
      • Use the Torx 6 screwdriver to remove these 2 screws.
      • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
      Ask FixBot
    5. Sidekick II Outer Casing Replacement: step 5, image 1 of 1
      • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
      • You can use your hands to simply pull apart the top casing from the bottom casing.
      Ask FixBot
Finish Line
Author
with
michael albaum
108 Reputation
6 Guides authored
Cal Poly, Team 3-19, Maness Winter 2010 Member of Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 85
All Time: 3,252
