Shure SM58 Faceplate Replacement
Views: 10K
View statistics:
Past 24 Hours:
8
Past 7 Days:
34
Past 30 Days:
133
All Time:
10,302
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
The faceplate connects all of the internal wiring of the microphone. If it is defective (or wires need to be reattached to it), this guide shows how to replace it.
Tools
    1. Shure SM58 Faceplate Replacement, Faceplate: step 1, image 1 of 1
      • Remove the yellow and green wires from the face plate.
      • Note which side the yellow and green wires connect to.
      Ask FixBot
    2. Shure SM58 Faceplate Replacement: step 2, image 1 of 2 Shure SM58 Faceplate Replacement: step 2, image 2 of 2
      • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
      • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
      Ask FixBot
    3. Shure SM58 Faceplate Replacement: step 3, image 1 of 2 Shure SM58 Faceplate Replacement: step 3, image 2 of 2
      • Slide the face plate over the connector.
      Ask FixBot
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
nat coll
868 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 133
All Time: 10,302
