Up to 20% off select tools
Shure SM58 Collar Replacement
Views: 16K
View statistics:
Past 24 Hours:
7
Past 7 Days:
29
Past 30 Days:
186
All Time:
16,022
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
The collar is the place the top and bottom of the microphone screw together. After unscrewing it, you will have access to most of the internal parts of the microphone.
    1. Shure SM58 Collar Replacement, Collar: step 1, image 1 of 3 Shure SM58 Collar Replacement, Collar: step 1, image 2 of 3 Shure SM58 Collar Replacement, Collar: step 1, image 3 of 3
      • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
      • Be careful to not pull on the collar or you may rip the wires from the faceplate.
      Ask FixBot
2 other people completed this guide.
Author
with
nat coll
868 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
180 Guides authored
1 Guide Comment
Gracias por la ayuda. me sirvió para descubrir en que punto esta la rosca para desarmarlo. lo que debo decir es que al collar para desenroscarlo debemos girarlo en sentido ANTIHORARIO de lo contrario lo estaríamos ajustando. debido a ese dato fallido luche un buen rato hasta darme cuenta
Mario Pessina - Reply Share
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 186
All Time: 16,022
