Up to 20% off select tools
Shower Handle O-ring Replacement
Views: 29K
View statistics:
Past 24 Hours:
16
Past 7 Days:
100
Past 30 Days:
422
All Time:
28,529
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If you have a shower head with a constant drip, follow this simple and easy guide to replace the rubber o-ring in your shower handle. Replacing the O-ring can help prevent hard water build up, rusting, and wasting water.
    1. Shower Handle O-ring  Replacement, Shower Handle O-ring: step 1, image 1 of 1
      • Be sure your water main is turned off, preventing water flow to your shower.
      • Using your flat head screwdriver, remove the screw from the middle of the handle.
      Ask FixBot
    2. Shower Handle O-ring  Replacement: step 2, image 1 of 1
      • Use your groove joint pliers to loosen and remove the escutcheon plate.
      Ask FixBot
    3. Shower Handle O-ring  Replacement: step 3, image 1 of 1
      • Using your groove joint pliers, loosen and remove the cartridge stem.
      Ask FixBot
    4. Shower Handle O-ring  Replacement: step 4, image 1 of 1
      • Slowly unscrew and remove the stem completely.
      • There may be some water leakage due to built up pressure.
      Ask FixBot
    5. Shower Handle O-ring  Replacement: step 5, image 1 of 2 Shower Handle O-ring  Replacement: step 5, image 2 of 2
      • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
      • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
      • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
      • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Cori Fitzpatrick
213 Reputation
1 Guide authored
4 Guide Comments
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Reply Share
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - Reply Share
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
Jess - Reply Share
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - Reply Share
Past 24 Hours: 16
Past 7 Days: 100
Past 30 Days: 422
All Time: 28,529
