Sharper Image SVC430 SD Card Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
105
All Time:
799
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The user will learn how to:
  • Remove the device from the case
  • Locate the memory card
  • Remove memory card
  • Insert memory card
    1. Sharper Image SVC430 SD Card Replacement, SD Card: step 1, image 1 of 2 Sharper Image SVC430 SD Card Replacement, SD Card: step 1, image 2 of 2
      • Power off your device before you begin this SD card replacement.
      • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
      Ask FixBot
    2. Sharper Image SVC430 SD Card Replacement: step 2, image 1 of 2 Sharper Image SVC430 SD Card Replacement: step 2, image 2 of 2
      • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
      Ask FixBot
    3. Sharper Image SVC430 SD Card Replacement: step 3, image 1 of 2 Sharper Image SVC430 SD Card Replacement: step 3, image 2 of 2
      • Locate the micro SD port at the bottom of the device by lifting up the panel.
      Ask FixBot
    4. Sharper Image SVC430 SD Card Replacement: step 4, image 1 of 2 Sharper Image SVC430 SD Card Replacement: step 4, image 2 of 2
      • To remove the micro SD card from the device, gently push the SD card and release. The SD card will pop out.
      • Be sure to gently push the SD card, pushing harder than necessary can cause the SD card or port to break.
      Ask FixBot
    5. Sharper Image SVC430 SD Card Replacement: step 5, image 1 of 1
      • When putting a micro SD card back into the device, be sure to place the exposed metal side up, as well as have the device LCD screen side up.
      Ask FixBot
    6. Sharper Image SVC430 SD Card Replacement: step 6, image 1 of 1
      • Gently push the micro SD back into the SD port until you hear a click!
      • Do not push the SD card hard. If it doesn't click, you may have the card the wrong way. Too much pressure can break the SD card or the SD port.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 105
All Time: 799
