Sharp-EL-531xg Battery Replacement
    1. Sharp-EL-531xg Battery Replacement, Battery: step 1, image 1 of 1
      • Press the 2nd F button and then the OFF button to power down the calculator.
      Ask FixBot
    2. Sharp-EL-531xg Battery Replacement: step 2, image 1 of 2 Sharp-EL-531xg Battery Replacement: step 2, image 2 of 2
      • Flip the calculator over so the back is facing upwards.
      • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
      Ask FixBot
    3. Sharp-EL-531xg Battery Replacement: step 3, image 1 of 1
      • Remove the battery cover using two fingers.
      Ask FixBot
    4. Sharp-EL-531xg Battery Replacement: step 4, image 1 of 3 Sharp-EL-531xg Battery Replacement: step 4, image 2 of 3 Sharp-EL-531xg Battery Replacement: step 4, image 3 of 3
      • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
      • Avoid using a sharp tool to remove the battery.
      Ask FixBot
    5. Sharp-EL-531xg Battery Replacement: step 5, image 1 of 1
      • Place the new battery into the slot with the positive (+) side facing upwards
      • Don't press the battery too hard.
      Ask FixBot
    6. Sharp-EL-531xg Battery Replacement: step 6, image 1 of 1
      • Put the battery cover back on.
      • Tighten the battery cover screw with a Phillips #0 screwdriver.
      Ask FixBot
    7. Sharp-EL-531xg Battery Replacement: step 7, image 1 of 2 Sharp-EL-531xg Battery Replacement: step 7, image 2 of 2
      • Press the On button to turn on the calculator.
      • Flip the calculator over so the bottom is facing upwards.
      • Press the reset button with the pointed end of a spudger to restart the calculator.
      Ask FixBot
Finish Line
Muhammad Hassan Majeed
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 44
All Time: 1,716
