Up to 20% off select tools
Sharp PC-MM20 Keyboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
92
All Time:
1,283
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
You'll be replacing the keyboard component of the Sharp PC - MM20!
    1. Sharp PC-MM20 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Make sure the laptop is powered down.
      • Remove the battery from the laptop.
      Ask FixBot
    2. Sharp PC-MM20 Keyboard Replacement: step 2, image 1 of 1
      • Close the laptop.
      • Turn the laptop so that the back is facing you.
      • There will be three screws on the back. Remove each screw by using the screw driver.
      Ask FixBot
    3. Sharp PC-MM20 Keyboard Replacement: step 3, image 1 of 1
      • Flip the laptop so that you can see the bottom.
      • Remove the screws shown in the picture.
      Ask FixBot
    4. Sharp PC-MM20 Keyboard Replacement: step 4, image 1 of 2 Sharp PC-MM20 Keyboard Replacement: step 4, image 2 of 2
      • Open the laptop and focus on the front of the base of the laptop.
      • Notice that there are small notches in between the two plates of the laptop. There are several slots such as this that are found across the front base of the laptop.
      • Take a flat edge and wedge it into the slot to pop it open.
      Ask FixBot
    5. Sharp PC-MM20 Keyboard Replacement: step 5, image 1 of 2 Sharp PC-MM20 Keyboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Once the cover is loose, it should be able to shift somewhat freely. However, there are a few more connections holding it together.
      • Use tweezers to delicately remove the flat cable that connects the keyboard to the laptop.
      • Remove the flat cable from the track pad of the laptop.
      Ask FixBot
    6. Sharp PC-MM20 Keyboard Replacement: step 6, image 1 of 1
      • Remove the top of the base from the rest of the computer.
      Ask FixBot
    7. Sharp PC-MM20 Keyboard Replacement: step 7, image 1 of 1
      • Lastly, take the old keyboard out of the base and replace it with the new keyboard.
      Ask FixBot
2 other people completed this guide.
Author
with
Logan Lindsey
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 92
All Time: 1,283
