Up to 20% off select tools
Sharp Microwave Door Switch Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
11
Past 7 Days:
60
Past 30 Days:
233
All Time:
7,126
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the door switch for the Sharp Microwave so that it will not turn on when the door is opened.
    1. Sharp Microwave Door Switch Replacement, Door Switch: step 1, image 1 of 2 Sharp Microwave Door Switch Replacement, Door Switch: step 1, image 2 of 2
      • Sharp microwave running with door open
      • Problem with the hardware interlock switches triggered by the door latch
      • Sharp model R-248BS
      • Unplug the microwave before you begin disassembly.
      Ask FixBot
    2. Sharp Microwave Door Switch Replacement, Remove screws: step 2, image 1 of 3 Sharp Microwave Door Switch Replacement, Remove screws: step 2, image 2 of 3 Sharp Microwave Door Switch Replacement, Remove screws: step 2, image 3 of 3
      • Side screw
      • ...and 4 screws in the back
      • Star screws need T15X4 or equivalent. A flathead can be used in a pinch.
      • Remove the screws
      Ask FixBot
    3. Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): step 3, image 1 of 3 Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): step 3, image 2 of 3 Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): step 3, image 3 of 3
      • Remove the case, should slide out with a little bit of effort.due to notches in the frame on the front top left ( when looking from the back).
      Ask FixBot
    4. Sharp Microwave Door Switch Replacement, Microwave with the cover open: step 4, image 1 of 3 Sharp Microwave Door Switch Replacement, Microwave with the cover open: step 4, image 2 of 3 Sharp Microwave Door Switch Replacement, Microwave with the cover open: step 4, image 3 of 3
      • Now we will identify the switches
      • The lower two switches
      • ... and the upper switch
      • Upper switch faulty
      Ask FixBot
    5. Sharp Microwave Door Switch Replacement, Replacement of the switch: step 5, image 1 of 3 Sharp Microwave Door Switch Replacement, Replacement of the switch: step 5, image 2 of 3 Sharp Microwave Door Switch Replacement, Replacement of the switch: step 5, image 3 of 3
      • Top switch appears loose
      • Replace and reinstall
      • Angled reinsertion to line up hole with plastic support
      Ask FixBot
Author
with
Sanjay Don
229 Reputation
2 Guides authored
2 Guide Comments
Some Sharp Microwaves use different Torx screws. The T15 didn't fit the screws on my model, it appears to be the security version of the T15. I suggest getting a set such as the Mako instead.
DBDigital - Reply Share
Sometimes 2 of 6 cabinet screws are security style. Adjusting small needle nose vise-grip pliers very tightly and pointed directly around round screw head parallel to screw thread can loosen the sheet metal screw.
Gordy L - Reply Share
Past 24 Hours: 11
Past 7 Days: 60
Past 30 Days: 233
All Time: 7,126
