Up to 20% off select tools
Sharp LC-42D62U T-Con Board Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
86
All Time:
2,083
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Parts
Tools
    1. Sharp LC-42D62U  T-Con Board Replacement, Remove the SD card cover: step 1, image 1 of 1
      • To replace the T-Con board it is not necessary to remove the base.
      • Lay the the TV flat on a padded surface.
      Ask FixBot
    2. Sharp LC-42D62U  T-Con Board Replacement, Detach the rear cover: step 2, image 1 of 1
      • Remove 17 screws.
      Ask FixBot
    3. Sharp LC-42D62U  T-Con Board Replacement, Remove the stand fixing angle: step 3, image 1 of 1
      • To reassemble all the parts easily, mark with a permanent marker the location of the screws you are removing.
      • 4 screws hold the nd fixing angle.
      Ask FixBot
    4. Sharp LC-42D62U  T-Con Board Replacement, Remove left and right center angles: step 4, image 1 of 1
      • 2 screws hold each center angles.
      Ask FixBot
    5. Sharp LC-42D62U  T-Con Board Replacement, Remove the main shield: step 5, image 1 of 1
      • 9 screws.
      Ask FixBot
    6. Sharp LC-42D62U  T-Con Board Replacement, Disconnect connectors: step 6, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    7. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray chassis: step 7, image 1 of 1
      • 7 screws.
      Ask FixBot
    8. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray fixing angles and the lug angle top: step 8, image 1 of 1
      • Remove the 7 screws holding the lug angle top.
      • Then remove only the bottom screws from the tray fixing angles, leaving the top screws attached to the lug angle top.
      Ask FixBot
    9. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: step 9, image 1 of 2 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: step 9, image 2 of 2
      • 5 screws.
      Ask FixBot
    10. Sharp LC-42D62U  T-Con Board Replacement, Remove the last screw and disconnect the 4 ribbon cables: step 10, image 1 of 1
      • To disconnect the ribbon cables, lift the brown tab on the connector.
      • Make sure the ribbons are positioned correctly in the connector when reassembling the new board.
      Ask FixBot
    11. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: step 11, image 1 of 2 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: step 11, image 2 of 2
      • There are two pads glued under the board (see yellow marks in the picture): use a heat gun to soften them and then gently pry them to detach the board from the frame.
      • There are also 4 tabs holding the board: gently pull the board to release it, after the pads are disconnected.
      • Reposition the pads on the chassis before installing the new board.
      Ask FixBot
Author
with
Emme
927 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 86
All Time: 2,083
