Sharp Aquos LC13B2UA Power Button Replacement
    1. Sharp Aquos LC13B2UA Power Button Replacement, Stand: step 1, image 1 of 2 Sharp Aquos LC13B2UA Power Button Replacement, Stand: step 1, image 2 of 2
      • Place the TV face down on a flat smooth surface as to not scratch the screen.
      • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
      Ask FixBot
    2. Sharp Aquos LC13B2UA Power Button Replacement: step 2, image 1 of 2 Sharp Aquos LC13B2UA Power Button Replacement: step 2, image 2 of 2
      • Lift the stand off the television.
      Ask FixBot
    1. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: step 3, image 1 of 3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: step 3, image 2 of 3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: step 3, image 3 of 3
      • Remove the two back panels by prying them out with your hands.
      Ask FixBot
    2. Sharp Aquos LC13B2UA Power Button Replacement: step 4, image 1 of 2 Sharp Aquos LC13B2UA Power Button Replacement: step 4, image 2 of 2
      • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
      • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
      Ask FixBot
    3. Sharp Aquos LC13B2UA Power Button Replacement: step 5, image 1 of 1
      • Using your hands, gently lift and remove the back case of the television.
      Ask FixBot
    1. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: step 6, image 1 of 3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: step 6, image 2 of 3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: step 6, image 3 of 3
      • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
      • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
      Ask FixBot
    2. Sharp Aquos LC13B2UA Power Button Replacement: step 7, image 1 of 2 Sharp Aquos LC13B2UA Power Button Replacement: step 7, image 2 of 2
      • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
      • Remove the green/gray to orange/gray connector from the center of the circuit board.
      Ask FixBot
    3. Sharp Aquos LC13B2UA Power Button Replacement: step 8, image 1 of 2 Sharp Aquos LC13B2UA Power Button Replacement: step 8, image 2 of 2
      • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
      Ask FixBot
    4. Sharp Aquos LC13B2UA Power Button Replacement: step 9, image 1 of 1
      • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
      Ask FixBot
    1. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: step 10, image 1 of 3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: step 10, image 2 of 3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: step 10, image 3 of 3
      • Remove the two 6mm Phillips screws.
      • Pull the board toward you, giving you access to the power button.
      Ask FixBot
Robert Hobson
1,290 Reputation
9 Guides authored
Cal Poly, Team 1-11, Amido Winter 2011 Member of Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 73
All Time: 7,750
