Sharp Aquos LC13B2UA LCD Replacement
    1. Sharp Aquos LC13B2UA LCD Replacement, Stand: step 1, image 1 of 2 Sharp Aquos LC13B2UA LCD Replacement, Stand: step 1, image 2 of 2
      • Place the TV face down on a flat smooth surface as to not scratch the screen.
      • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
      Ask FixBot
    2. Sharp Aquos LC13B2UA LCD Replacement: step 2, image 1 of 2 Sharp Aquos LC13B2UA LCD Replacement: step 2, image 2 of 2
      • Lift the stand off the television.
      Ask FixBot
    1. Sharp Aquos LC13B2UA LCD Replacement, Back Case: step 3, image 1 of 3 Sharp Aquos LC13B2UA LCD Replacement, Back Case: step 3, image 2 of 3 Sharp Aquos LC13B2UA LCD Replacement, Back Case: step 3, image 3 of 3
      • Remove the two back panels by prying them out with your hands.
      Ask FixBot
    2. Sharp Aquos LC13B2UA LCD Replacement: step 4, image 1 of 2 Sharp Aquos LC13B2UA LCD Replacement: step 4, image 2 of 2
      • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
      • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
      Ask FixBot
    3. Sharp Aquos LC13B2UA LCD Replacement: step 5, image 1 of 1
      • Using your hands, gently lift and remove the back case of the television.
      Ask FixBot
    1. Sharp Aquos LC13B2UA LCD Replacement, Motherboard: step 6, image 1 of 3 Sharp Aquos LC13B2UA LCD Replacement, Motherboard: step 6, image 2 of 3 Sharp Aquos LC13B2UA LCD Replacement, Motherboard: step 6, image 3 of 3
      • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
      • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
      Ask FixBot
    2. Sharp Aquos LC13B2UA LCD Replacement: step 7, image 1 of 2 Sharp Aquos LC13B2UA LCD Replacement: step 7, image 2 of 2
      • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
      • Remove the green/gray to orange/gray connector from the center of the circuit board.
      Ask FixBot
    3. Sharp Aquos LC13B2UA LCD Replacement: step 8, image 1 of 2 Sharp Aquos LC13B2UA LCD Replacement: step 8, image 2 of 2
      • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
      Ask FixBot
    4. Sharp Aquos LC13B2UA LCD Replacement: step 9, image 1 of 1
      • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
      Ask FixBot
    1. Sharp Aquos LC13B2UA LCD Replacement, LCD: step 10, image 1 of 1
      • Flip the LCD/circuit board so that the circuit board faces up.
      Ask FixBot
    2. Sharp Aquos LC13B2UA LCD Replacement: step 11, image 1 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 11, image 2 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 11, image 3 of 3
      • Remove the three 5mm Philips screws attaching the circuit board to the LCD.
      • Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD.
      Ask FixBot
    3. Sharp Aquos LC13B2UA LCD Replacement: step 12, image 1 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 12, image 2 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 12, image 3 of 3
      • Turn the circuit board so the blue and pink side cables are facing you.
      • Hold the white plastic, squeeze and pull from the sides.
      Ask FixBot
    4. Sharp Aquos LC13B2UA LCD Replacement: step 13, image 1 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 13, image 2 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 13, image 3 of 3
      • Turn the television so the right hand side is facing you.
      • To remove the ribbon cables, fold the brown casing down and pull directly upward on the ribbon.
      • Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
      Ask FixBot
    5. Sharp Aquos LC13B2UA LCD Replacement: step 14, image 1 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 14, image 2 of 3 Sharp Aquos LC13B2UA LCD Replacement: step 14, image 3 of 3
      • Turn the circuit board so that the left side is facing you.
      • Detach the data cable from the circuit board.
      • To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
      Ask FixBot
    6. Sharp Aquos LC13B2UA LCD Replacement: step 15, image 1 of 1
      • Lift and remove the circuit board from the LCD frame.
      Ask FixBot
    7. Sharp Aquos LC13B2UA LCD Replacement: step 16, image 1 of 1
      • Now you have your LCD.
      Ask FixBot
2 other people completed this guide.
Robert Hobson
1,290 Reputation
9 Guides authored
Cal Poly, Team 1-11, Amido Winter 2011 Member of Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 37
All Time: 9,030
