Up to 20% off select tools
Sharp Aquos Crystal USB Port Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
104
All Time:
3,402
Comments: 5
5 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You may need to replace your USB port if you are unable to charge your phone or if your phone charges slowly.
This guide will take tell you what tools you need and how to open your device and get to the USB component.
    1. Sharp Aquos Crystal USB Port Replacement, Back Panel: step 1, image 1 of 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: step 1, image 2 of 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: step 1, image 3 of 3
      • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
      Ask FixBot
    1. Sharp Aquos Crystal USB Port Replacement, USB Port: step 2, image 1 of 2 Sharp Aquos Crystal USB Port Replacement, USB Port: step 2, image 2 of 2
      • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
      Ask FixBot
    2. Sharp Aquos Crystal USB Port Replacement: step 3, image 1 of 2 Sharp Aquos Crystal USB Port Replacement: step 3, image 2 of 2
      • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
      Ask FixBot
    3. Sharp Aquos Crystal USB Port Replacement: step 4, image 1 of 2 Sharp Aquos Crystal USB Port Replacement: step 4, image 2 of 2
      • Disconnect the wire by lifting it up with a plastic opening tool.
      Ask FixBot
    4. Sharp Aquos Crystal USB Port Replacement: step 5, image 1 of 3 Sharp Aquos Crystal USB Port Replacement: step 5, image 2 of 3 Sharp Aquos Crystal USB Port Replacement: step 5, image 3 of 3
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      Ask FixBot
    5. Sharp Aquos Crystal USB Port Replacement: step 6, image 1 of 1
      • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
      Ask FixBot
2 other people completed this guide.
Author
with
Felicia Imbriano
1,266 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 104
All Time: 3,402
