Sharp Aquos Crystal Motherboard Replacement
    1. Sharp Aquos Crystal Motherboard Replacement, Back Panel: step 1, image 1 of 3 Sharp Aquos Crystal Motherboard Replacement, Back Panel: step 1, image 2 of 3 Sharp Aquos Crystal Motherboard Replacement, Back Panel: step 1, image 3 of 3
      • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
      Ask FixBot
    1. Sharp Aquos Crystal Motherboard Replacement, USB Port: step 2, image 1 of 2 Sharp Aquos Crystal Motherboard Replacement, USB Port: step 2, image 2 of 2
      • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
      Ask FixBot
    2. Sharp Aquos Crystal Motherboard Replacement: step 3, image 1 of 2 Sharp Aquos Crystal Motherboard Replacement: step 3, image 2 of 2
      • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
      Ask FixBot
    3. Sharp Aquos Crystal Motherboard Replacement: step 4, image 1 of 2 Sharp Aquos Crystal Motherboard Replacement: step 4, image 2 of 2
      • Disconnect the wire by lifting it up with a plastic opening tool.
      Ask FixBot
    4. Sharp Aquos Crystal Motherboard Replacement: step 5, image 1 of 3 Sharp Aquos Crystal Motherboard Replacement: step 5, image 2 of 3 Sharp Aquos Crystal Motherboard Replacement: step 5, image 3 of 3
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      Ask FixBot
    5. Sharp Aquos Crystal Motherboard Replacement: step 6, image 1 of 1
      • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
      Ask FixBot
    1. Sharp Aquos Crystal Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • Peel off the black pieces of tape.
      Ask FixBot
    2. Sharp Aquos Crystal Motherboard Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
      Ask FixBot
    3. Sharp Aquos Crystal Motherboard Replacement: step 9, image 1 of 2 Sharp Aquos Crystal Motherboard Replacement: step 9, image 2 of 2
      • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
      Ask FixBot
    4. Sharp Aquos Crystal Motherboard Replacement: step 10, image 1 of 1
      • Peel the tape off with your hands.
      Ask FixBot
    5. Sharp Aquos Crystal Motherboard Replacement: step 11, image 1 of 1
      • Lift the motherboard out with your hands.
      Ask FixBot
2 other people completed this guide.
Felicia Imbriano
1,266 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 122
All Time: 3,577
