Up to 20% off select tools
Sharp Aquos Crystal Battery Replacement
Views: 20K
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
145
All Time:
19,588
Comments: 8
5 comments on steps, 3 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 35 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If your phone is not turning on or charging, you may need a new battery.
This guide will show you how to open your device and remove the inside motherboard to replace your battery.
    1. Sharp Aquos Crystal Battery Replacement, Back Panel: step 1, image 1 of 3 Sharp Aquos Crystal Battery Replacement, Back Panel: step 1, image 2 of 3 Sharp Aquos Crystal Battery Replacement, Back Panel: step 1, image 3 of 3
      • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
      Ask FixBot
    1. Sharp Aquos Crystal Battery Replacement, USB Port: step 2, image 1 of 2 Sharp Aquos Crystal Battery Replacement, USB Port: step 2, image 2 of 2
      • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
      Ask FixBot
    2. Sharp Aquos Crystal Battery Replacement: step 3, image 1 of 2 Sharp Aquos Crystal Battery Replacement: step 3, image 2 of 2
      • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
      Ask FixBot
    3. Sharp Aquos Crystal Battery Replacement: step 4, image 1 of 2 Sharp Aquos Crystal Battery Replacement: step 4, image 2 of 2
      • Disconnect the wire by lifting it up with a plastic opening tool.
      Ask FixBot
    4. Sharp Aquos Crystal Battery Replacement: step 5, image 1 of 3 Sharp Aquos Crystal Battery Replacement: step 5, image 2 of 3 Sharp Aquos Crystal Battery Replacement: step 5, image 3 of 3
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      Ask FixBot
    5. Sharp Aquos Crystal Battery Replacement: step 6, image 1 of 1
      • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
      Ask FixBot
    1. Sharp Aquos Crystal Battery Replacement, Motherboard: step 7, image 1 of 1
      • Peel off the black pieces of tape.
      Ask FixBot
    2. Sharp Aquos Crystal Battery Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
      Ask FixBot
    3. Sharp Aquos Crystal Battery Replacement: step 9, image 1 of 2 Sharp Aquos Crystal Battery Replacement: step 9, image 2 of 2
      • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
      Ask FixBot
    4. Sharp Aquos Crystal Battery Replacement: step 10, image 1 of 1
      • Peel the tape off with your hands.
      Ask FixBot
    5. Sharp Aquos Crystal Battery Replacement: step 11, image 1 of 1
      • Lift the motherboard out with your hands.
      Ask FixBot
    1. Sharp Aquos Crystal Battery Replacement, Battery: step 12, image 1 of 1
      • Peel off the tape holding the battery down.
      Ask FixBot
    2. Sharp Aquos Crystal Battery Replacement: step 13, image 1 of 2 Sharp Aquos Crystal Battery Replacement: step 13, image 2 of 2
      • Lift the battery out with your hands.
      Ask FixBot
9 other people completed this guide.
Author
with
Felicia Imbriano
1,266 Reputation
8 Guides authored
3 Guide Comments
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - Reply Share
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - Reply Share
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - Reply Share
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 145
All Time: 19,588
