Introduction
This guide will provide instruction on how to clean and replace the filter of the Shark UltraCyclone CH951. The filter is a foam part that is covered with felt. The filter stops debris from entering the motor and damaging the interior of the vacuum. If the filter gets clogged or has a defect, it will need to be replaced. This is an easy process.
Press the dust cup release button and gently pull the dust cup away from the body of the vacuum.
Place your fingers under the black tab on the plastic holder. Gently pull towards you.
