Shark UltraCyclone CH951 U4 Casing Replacement
    1. Shark UltraCyclone CH951 U4 Casing Replacement, Dust Cup: step 1, image 1 of 3 Shark UltraCyclone CH951 U4 Casing Replacement, Dust Cup: step 1, image 2 of 3 Shark UltraCyclone CH951 U4 Casing Replacement, Dust Cup: step 1, image 3 of 3
      • Press the dust cup release button and gently pull the dust cup away from the body of the vacuum.
      Ask FixBot
    1. Shark UltraCyclone CH951 U4 Casing Replacement, Casing: step 2, image 1 of 2 Shark UltraCyclone CH951 U4 Casing Replacement, Casing: step 2, image 2 of 2
      • Use a TR9 Torx screwdriver to remove the two 8.7 mm screws previously behind the dust cup.
      Ask FixBot
    2. Shark UltraCyclone CH951 U4 Casing Replacement: step 3, image 1 of 1
      • Remove the two 12.2 mm screws underneath the dust cup button using a TR9 Torx screwdriver.
      Ask FixBot
    3. Shark UltraCyclone CH951 U4 Casing Replacement: step 4, image 1 of 1
      • Remove the 13.9 mm screw beneath the charging port using a TR9 Torx screwdriver.
      Ask FixBot
    4. Shark UltraCyclone CH951 U4 Casing Replacement: step 5, image 1 of 1
      • Use the TR9 Torx screwdriver to remove two 11.6 mm screws that hold the exterior motor in place.
      • They are located underneath where the dust cup previously was and above the exterior motor.
      Ask FixBot
    5. Shark UltraCyclone CH951 U4 Casing Replacement: step 6, image 1 of 3 Shark UltraCyclone CH951 U4 Casing Replacement: step 6, image 2 of 3 Shark UltraCyclone CH951 U4 Casing Replacement: step 6, image 3 of 3
      • Run an iFixit Opening Tool under the casing along the vacuum body until the shell is removed starting around the attachment port, and sliding down towards the charging port.
      • If necessary, apply gentle force.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 39
All Time: 528
